TRI GLIDE honest opinion
#121
The '09 TG goes in for new front tire and oil change first of March. One of the posters mentioned Redline Shockproof transmission fluid...is this something the dealer stocks, or do they just use Syn3?
Would changing to the 30T sprocket help, or just 'spinning my wheels' w/added cost?
I have no issues with heat or power....
Thanks.
Thanks.
If you’re satisfied with the off-line and 6th gear performance of your TG; why make the change. Personally I’m waiting to hear some reports from some of the guys that made the 30T switch.
Jim
#122
#123
Barbra, some dealers may stock Redline Shockproof but I suspect most do not. You may have to bring your own at time of service.
Jim
Jim
Picked up Redline at Cycle Addiction (Nampa)...date at HD dealer for front tire/15K service set for 3/2. Not doing the 30T sprocket...
B
#124
#125
#126
Joan, I doubt that you can get a 30T installed for $250.
You do not need to buy a new PC-V when you install your cams.It’s just a matter of downloading a new map.
Jim
#127
Hey All,
You might want to look into Mobil One LT 75-140 gear oil for your transmissions. Mobil One also offer LT 75-90 that is a bit less expensive for colder climates. It's available at your local Autozone. Been using it for years even in my 93 FXLR with the Baker DD6. Great stuff and we use the 75-140 due to the hotter ambient temps down here.
It's going into my Tri at the first service along with the Redline 20-50 Oil in the engine. Due to the SE comp fretting issue, I'll use HD Primary + instead of MTL as planned. This is partially due to the results on the inspections of M1 and M3's compensators. I also have to order a case of Redline 20-60 as our distributor does not carry it.
Although my boss sells the Redline products, we gotta charge a bit extra whenever doing a trans job as the Redline is very messy, is extremely hard to clean up and will hold water. Just my opinion changing seals and gaskets, so take it FWIW.
#128
Hey Buddy, as long as you are using RedLine motor oil why dont you try some RedLine Pepto Bismol (Heavy shockproof) in the trans.? I know its hard to try something other than what you like but im pretty impressed with it, what the heck , all one brand in all the holes ( they make a primary oil also).
#129
#130
There are several threads going on in the Touring and I think the CVO sections about "fretting" or many would call it galling on the SE compensator that our trikes use. Owners of earlier model bikes have also be retro fitting to the SE parts. The consensus seems to be more of a problem with this when using thinner oils in the primary. When M1 and M3's were checked, Mike said they looked good one bike at 10K, the other much over that. He has been using nothing but HD Primary +. Just trying to get my ducks in a row and use products that have proven themselves.
