Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
30 tooth sprocket
Old 11-01-2010, 03:10 PM
icebite1's Avatar
icebite1
icebite1 is offline
Originally Posted by roger scarcliff
Thanks, turns out the speedo was not off by 10 mph after all. It was maybe 2-3 mph, so I just left it alone and have 6th light and cruise.
That sounds pretty close to the norm of 5mph off with the 30t change. If you already have the speedo cal unit you can adjust the speed some without losing your light, if you lose your light just back up a step. The pulley change and speedo cal should have no effect on your cruise.
  #32
Old 11-02-2010, 06:53 PM
Boom's Avatar
Boom
Boom is offline
I'm getting my pulley replaced by dealer on 11/11---a notable date for all. It's also the 1st anniversary of my TG purchase. And yes, I will be a guinea pig for this install. They haven't done a TG before but many replacements on two-wheelers. I WILL be very particular on that belt alignment!
  #33
Old 11-03-2010, 08:50 AM
icebite1's Avatar
icebite1
icebite1 is offline
The TG pulley change is easier than any other model because they dont have to replace the belt so it should be quick and easy for them as everything else is identical to other bikes except the rear tires have to be off for the belt adjustment, then its just a matter of making an accurate measurement, it has to be within 1/16' or less side to side, in this case less is better.
  #34
Old 11-03-2010, 12:50 PM
TheJimer's Avatar
TheJimer
TheJimer is offline
2-3 mph is more like it. I can live with that.
Thanks for the update.
Jim
2011 Road Glide Ultra
09-04-2015 04:55 PM
grandpawmoses
06-07-2011 06:25 PM
twothousandfour-supr-glide
01-11-2011 10:34 AM
msocko3
20
10-10-2010 04:54 AM
George D
03-28-2009 01:45 PM
Quick Reply: 30 tooth sprocket
