My '10 Triglide lost its passing lamp power plus the li'l rocker switch which actuates them doesn' even light up. Tyring to avoid a dealer trip, so I checked all fuses but could not find one blown. I'm thinkng maybe a loose wire somewhere? Anyone had this happen and what was the fix? If you say a fuse, which one, please, the fus box cover markings don't show one for passing lamps.
Thanks, 10Glider
Thanks, 10Glider
I can think of either the switch is bad or there is no power going to the switch. Doubt if your lights are the issue. If the indicator worked then there would be power to and out of the switch.
Bad switch or broken wire (power failure) to the switch would be my call. Sorry don't know which fuse but your manual does.
yellow wire from hi/lo handlebar switch takes power to spot switch on faring dash, if lo beams work stop looking for a fuse, you have a wire off somewhere. good chance connector on back of spot switch is off or loose
switch light on our '10 is off when hi beams are on
YEP... you are absolutely correct.. checked mine. The switch should be in the down position to the rider and the light goes out when the high beams are on..
the spot switch connector should be able to be seen with a light by looking under the housing on left side. 3 wires , yellow-power from hi/lo switch, black-ground for switch light, and grey with black trace-sends power to passing spot lamps when spot switch is on.
