Exhaust and A/C
I cooled my stock TG engine oil temp down from 300* on a 110* day to 240* on a 118* day!
See my signature for a list of mods; also see my post “Comprehensive TG Hot Weather Test Report”.
Jim
I can only speak to Fuel Moto’s Jack pot head pipes; I have a set of them on 2009 TG and could not be happier. However, keep in mind that depending upon what the average OAT you operate in is; head pipes and A/C may not be enough. I would suggest that at minimum you will also require a fuel management to richen the mixture.
Jim
Jim
Afr
A+! Remember that your engine is basicall an "air pump". More air in, more air out---great, but you also need to add fuel. And the heat is coming from the factory A.F.R. If your only goal is to cool it down, you could skip the air intake and the pipes and just get a fuel management system that will change your A.F.R. to a richer mixture and that will cool the engine down.
The Cat has to go if you want to get the total benifit from raising the AFR! Fuel Motto has a good headpipe and I understand Fullsac also sells a ceramic "catless" headpipe"
I have a couple of interesting question after reading the past posts
in this thread. Only because I don't have an extra $1500+ hanging
around BUT would like to maybe do it alittle at a time.
If you could answer each separatly .... thanks .....
Rob .....
1.) Could you just replace the headpipe and leave the rest stock ?
Wouldn't the stock EFI make the appriate corrections like when you
replace stock muffles.
2.) Could you just replace the headpipe and add say a PC 5 and leave the
stock AC & pipes ?
3.) Could you just replace the headpipe and add say a PC 5 & high flow AC and leave the stock pipes ?
Rob .....
stock AC & pipes ?
Rob .....
stock AC & pipes ?
Rob .....
stock AC & pipes ?
Actually by the 3rd week in August the heat will be gone.
Like I mentioned before the last 2 Summers here it RARELY got over
80 degrees and at 80 degrees the heat is a non issue for Lynn.
Lynn said she will just ride her 02 Dyna when it is over 80 degrees and
she wants to ride. As for the recession .... well I want to know where
that is ... LOL ...
We stopped at our dealer last weekend and just one of his salepersons
sold 15 NEW bikes (2010's) that week alone. Mind you that is pretty
darn good for a small shop in this area.
Rob .....
BTW ... I ordered a IR heat gun off amazon and it ships today.
Interested to see the actual temps finally in person :-)
Rob .....
stock AC & pipes ?
Rob .....
stock AC & pipes ?
Product choice and timing is the key. The perception of what is good for the Goose is good for the Gander doesn't always apply.
