Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Trailer Hitch ... Tri Glide
Old 09-14-2009, 08:09 AM
JSH's Avatar
JSH
JSH is offline
Default Trailer Hitch ... Tri Glide
I received from Bushtec their Tri Glide Trailer Hitch Friday, per instructions 4 bolts out ... 4 bolts (provided by Bushtec) in. Instruction did not include torque settings. These are frame to body bolts. Does anyone know the torque settings?
Also, took quick trip to AL and picked up used Bushtec Roadstar trailer. Anyone out here pulled a trailer with a Tri Glide?
thanks...John
Old 09-14-2009, 08:35 AM
krw's Avatar
krw
krw is offline
What size are the bolts? Here is a web site that might help:
http://www.sizes.com/tools/bolts_SAEtork.htm
Old 05-31-2018, 08:22 PM
mcride's Avatar
mcride
mcride is offline
Just came home from a 9,3032 mile trip. Pulled a Kompact Kamp trailer. Also did a 6,375 trip last summer pulling the same trailer. The only problem I had was I got a flat tire on the trailer last trip and when I pulled in for gas in Iowa the guy next to me asked me if I knew I had a flat. I didn't know and the bike never even pulled or struggled. I did some crazy roads both years: 80 mile speed limits, low altitude, high altitude and roads closed due to snow, mud and rock slides. Mountain passes that were unbelievable. Never even knew the trailer was behind me. You will love it.
Old 05-31-2018, 08:34 PM
Casper's Avatar
Casper
Casper is offline
We have a 2005 Bushtec Roadstar Trailer, love it...I’ve painted it five times, need to stop trading, lol
they make one of the best around
Old 05-31-2018, 10:37 PM
Firebike32's Avatar
Firebike32
Firebike32 is offline
We're pulling an '03 Aluma behind our '16 TG. Can hardly tell it's there.
Old 06-01-2018, 07:04 AM
cochon's Avatar
cochon
cochon is offline
We're pulling a Mission3x4MT. It's kind of an Aluma clone. So far, we have pulled it over 30,000 miles, through all of the lower 48 states, with nary a complaint.
Old 06-01-2018, 11:06 AM
Coastal CVO's Avatar
Coastal CVO
Coastal CVO is offline
Just did pretty much the same thing you are doing.
Bushtech Hitch and wiring kit, by the way, the instructions are misleading for the plug locations, the plug you will need to find is under the flap between the passenger backrest and seat.
As for the torque, I used a spot of loctite red and 10 inch pounds, probably a little light on the torque but good and snug, the loctite should keep them that way.
Old 06-01-2018, 02:01 PM
Coastal CVO
"These are frame to body bolts"
The bolts hold the hitch to the frame and are not body bolts, they do not hold the body at all.
UltraV
12-12-2017 09:53 AM
LADNAR
09-03-2011 04:36 PM
BigJfxdwg
07-13-2010 03:26 PM
reeac
07-21-2009 06:12 PM
Mississippi Bagger
01-31-2008 05:22 PM
Quick Reply: Trailer Hitch ... Tri Glide
