Tri-Glide Issues
#581
2016 Tri Glide. Won't spin the reverse motor. R blinks when button pushed. Yes, it's in neutral and motor running. Have used it many times. At the same time the "check engine" light has come on, stays on. I cycled the reverse circuit breaker off and back on a couple times. No problem there. Any ideas?
There are many people that use the reverse like they would in a car. It was never meant to be used as such. Sadly the motor is a small motor that is easily over worked especially when held in for more than a few seconds at a time. there are also problems with water, and the internal grease getting into the brushes. This or just plain wearing out from use. Check to see if you are getting the power to the motor when the button is pushed and go from there. There is also a relay to check.
There are motor kits for rebuilding and or complete replacement of the motor for sale on EBay.
motopete (03-20-2022)
#583
circuit diagram for reverse
Can anyone help with the circuit between the R handlebar switch and the solenoid on the reverse electric motor? Battery is over 12V; 150 amp circuit breaker is OK and I have 12V on the main feed to the solenoid. However, when R handlebar switch is pushed I do NOT get 12V at the activator/trigger feed on the solinoid and dashboard R blinks. What is between the switch and the starter solenoid, a relay? Where?
Error code is P1775, which means error in reverse system. PN is 70900121A, but I don't know what that is.
I know the reverse motor is an issue and have avoided using it, though it did work. I doubt the motor is the issue, especially since it is not getting 12V at the activator on the solenoid.
I really don't want to buy yet another service manual and trike supplement. I have so many manuals - ha! but not the right one - and I don't know how long I'll keep this Tri Glide.
Any help would be appreciated.
#584
I'm not sure on your year model what lockouts the reverse has. Make sure of all the control fuses also.
If you go to the Harley Davidson web site and register your trike there with the serial # you can access their wiring diagrams for your machine. You can also blow up the drawings and also print them out.
#585
Did all the things suggested including a print out of the wiring diagram, but gave up when I couldn't get 12V to the trigger on the solanoid near the 150 amp circit breaker. Called the dealer and made an appointment. At least the service manager listened to me and agreed it's probably not the electric motor itself. Thanks for all the info.
sloufoot (03-26-2022)
#586
Can't get the intercom to turn on.
I bought a 2022 Tri-Glide. I can't get the intercom to turn on. I start at Home and then go to Com. I assume the com is the headphone icon on the home screen.# 14. I can highlight it, but nothing happens. I touch it, I enter with the hand switch, but nothing happens. Any help would be appreciated. Thanks.
#587
#588
IzzoQuazzo (06-20-2022)
#589
#590
Received 22,055 Likes
DK Custom (02-17-2024)
