Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri-Glide Issues
Old 11-23-2016, 07:03 AM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
Kind of wondering about that statement too.
  #502
Old 11-23-2016, 03:25 PM
msocko3's Avatar
msocko3
msocko3 is offline
It's pretty much like the statement "You can't always believe what you see on the internet". I had one Harley tech tell me that when I was explaining why he was wrong, problem was he didn't know I could prove he was wrong. I will say there are some folks on the internet who are full of **** clean up to their eyeballs, you just have to read between the lines to sniff out the BS.
  #503
Old 11-23-2016, 05:32 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,625 Likes on 1,623 Posts
great, now you have a tech that don't know what he's talking about wanting to align your trike. that's why i hate going to the dealers for anything.
  #504
Old 11-23-2016, 08:47 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
Major reason I use an indie unless it's a simple fix or is warranty related. No choice in the latter unless I want to pay for it out of pocket.
  #505
Old 11-23-2016, 09:40 PM
LS Bob's Avatar
LS Bob
LS Bob is offline
Yeah, I have a trike with 600 miles on it needing what turns out to be both shocks replaced because they are leaking and apparently a senior tech doing hours of work that was not needed.
And last time I checked, my indie doesn't do warranty repair.
Pretty confusing.
  #506
Old 11-23-2016, 09:52 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
W/o question, that sucks big time. I've racked up over 17k on my '16 since I bought it in May. Only issue is the refrigeration unit for the beer cooler won't fit in the tour pack.
  #507
Old 03-30-2017, 11:59 PM
Smokee's Avatar
Smokee
Smokee is offline
Default Starting in gear
Originally Posted by BinIdaho
Mike,
Aha, maybe this is why sometimes it'll start in gear and other times not..and its really hard to find neutral, especially when the group is ready to leave and I'm still sitting
FYI y'all....When the Tri Glide is in gear, the clutch must be pulled in, AND the brake (either one) has to be applied or it won't crank.
  #508
Old 04-07-2017, 07:02 PM
Packers-FLSTC's Avatar
Packers-FLSTC
Packers-FLSTC is offline
How do you keep the trunk lid from popping open as you ride. My 2014 Tri-Glide lid opens even after I give it an extra tug to make sure it is secure. Any ideas to keep it closed?
How do I learn how to use this blog. I am new to them and they make no sense. I worked 2 hours to get this far.
  #509
Old 04-07-2017, 10:05 PM
Pappy51's Avatar
Pappy51
Pappy51 is offline
Mine popped open a couple times so I make sure to lock it and have no problems since.
  #510
Old 04-09-2017, 06:59 AM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
Don't slam it shut, the box is pretty tight and the air caught inside prevents the door latch from catching fully. Just close it until nearly shut, then firmly push it the rest of the way until you hear the 'click' of the latch. Once a lot of people started doing that, the problem seems to go away. If that doesn't work, it's out of adjustment.
This isn't a blog, it's in a pretty much standard forum format, if that makes any difference. Put your mouse pointer over the Forums button on the upper left of any page and a list comes down; slide down to Harley Davidson Motorcycles line and a list of models pops up just to the right. Slide over to that column and down to the Tri Glide and Freewheelers choice, you probably have to scroll down a bit to see it on the bottom of the popup, and click, it takes you directly to this forum section.
Once you find the Tri Glide page, make a bookmark so you can come back easily. Use the Advanced Search option to find things around here. Tons of info and some great folks that are a lot of help. Welcome to the forum!
Quick Reply: Tri-Glide Issues
