shock removing
shock removing
2023 rg, Can the shocks be changed with out removing the trunk ? Also what is in the shock adjuster, I don't think it's air, maybe oil? The shop manual states to not disconnect it, why, is it the same if you remove the tag on your mattress ?
The following 2 users liked this post by Longbeard71:
ChopperBill (Yesterday),
snipit (Yesterday)
I have removed the trunk from both of my Triglides. I also replaced the shocks the first time without removing the trunk. I learned removing the trunk is so easy, I was mad for not having done it before.
I do remove the tour pack, but not the fenders. I get a helper to lift the trunk off and back on, but it lines up so well everything goes back perfectly.
Check YouTube for trunk removal video and see what those of us who have removed the trunk mean when we recommend it for a way to make your life easier. Lots of stuff is easier to do with it off.
