NOTE: Trike tire load ratings NOT the same for all models & all model years!
Received 21,949 Likes
Just a note as there are a few differences between the Tri-Glide & RG3 besides the tires & rim sizes that may contribute to ride differences.
Looks like there is a difference in the shock absorbers for one:
Tri-Glide Shocks: PN 54000144
SHOCK,RR,LH/RH,EMULSION,W/DIAL ADJUST | complete (2 shocks)
Price: $1,010.22
RG3 Shocks: 54000146
Price: $1,010.22
Price: $1,010.22
Price: $1,010.22
Price: $1,010.22
Price: $1,010.22
Price: $1,010.22
Price: $1,010.22
Jim G
The point is, trikes do use passenger car tires. Using the recommended tire pressure of 32 psi is much too stiff for the given load. Going down to low 20s is absolutely legit to run the tire in the proper range for traction, wear and comfort.
Your tires give max load ratings as all tires do, and recommended tire pressure for the application. Nobody ever claimed all ratings apply to all tires and all applications.... That there is a blanket statement for all trikes. We already know the low profiles tires on the new trikes are not the same.
My load ratings say recommended tire pressure for my F-250 super duty is 65 psi... Ya, when I have MAX payload which I rarely do. Unloaded, that's improper inflation and pretty unbearable. I run my tires 40 F and 35 R for proper wear and traction unloaded. That is 100% accurate pressure for the tires unloaded.
Trikes are no different. You buy the appropriate load rating for tires, not just proper size. You run the appropriate tire pressure for a given load regardless of old or new. Max rating is a limit.
ChopperBill (08-24-2024)
I did a tire pressure check testing 80 km ride this morning on my 2023 RG3 with tis low profile tires. Because I am in "metric" Canada, my tire psi numbers display in Kpa, not psi. But here is what the test results showed:
HD's recommended cold psi = Front 248 Kpa / 36 psi Rear 179 Kpa / 26 psi (Note: 6.88 multiplier from psi to get Kpa)
Actual cold psi from dealer = Front 244 Kpa / 35.5 Rear 182 Kpa / 26.5 psi
Actual Hot after 80 km = Front 260 Kpa / 37.8 Rear 188 Kpa / 27.3 psi
% increase from cold to hot = Front 6.5% Rear 3.3%
Given that most tire experts say that a 10% increase in tire pressure when hot versus cold generally gives the best tire performance, it would seem, that at least for a lone rider without passenger or luggage, both the front and rear recommended tire pressures for my 2023 RG3 are too high, with the rear being particularly too high.
The ride did not feel harsh this morning during this tire pressure test. But, on the other hand, it did not feel plush either, and some road bumps DID feel pretty hard.
I wonder how how much lower I could go with the tire pressures without the TPMS warning lighting up.
Jim G
Jim G
Writing that is consise and focused aids reading enjoyment.
