Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Do the trunks on newer trikes reliably keep your luggage dry?
Old 08-11-2024 | 11:48 AM
Sportster1952's Avatar
Sportster1952
I too avoided gravel on 2 wheels but now search it out to see new things. No problem on a Trike.
Old 08-11-2024 | 03:35 PM
agapsdiver's Avatar
agapsdiver
My temporary fix to the Triglide seal with rubber foam weather stripping.
Triglide Trunk water leak fix - Harley Davidson Forums (hdforums.com)
Old 08-11-2024 | 04:09 PM
JimGnitecki's Avatar
JimGnitecki
Inexpensive and smart temporary solution! Especially practical if leakage starts during a long trip far from home. There's a Home Depot reasonably close to almost everywhere.
Jim G
Old 08-11-2024 | 04:27 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by JimGnitecki
Hey Kevin, how well do ABS and traction control work on GRAVEL or dirt? I have studiously avoided gravel and ort roads on my 2-wheeler, but would they be significantly safer on a trike?
Jim G
ABS and Traction Control work well on wet asphalt & pavement. Also have had them both work well on gravel, dirt, sand and grass.
I prefer not to ride on gravel, only to reduce the change of kicking up a stone into my belt. That said, my driveway is gravel and I ride on it pretty much everyday and have not had a problem.
Definitely safer than on two wheels, not going to slide or slip and fall over.
Kevin
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 08-15-2024 | 09:03 AM
priell3's Avatar
priell3
No problem with water in the trunk of my wife's 2017 Freewheeler in torrential rain or when getting washed.
Old 08-17-2024 | 08:01 AM
mltdwn's Avatar
mltdwn
2020 TGU. Been in torrential rains. Trunk and top case bone dry. I do always lock the trunk.
stevewfl
Touring Parts
10-07-2019 09:00 AM
2006FLST
Softail Parts
04-12-2011 10:08 AM
whocares
08-08-2010 12:57 PM
JCK
07-31-2009 08:44 AM
bosken
07-22-2008 08:24 PM
