EXTENSION, HEADER PIPE Removal
So I decided to prep for the installation of my 14.5" SuperShox for my 2022 Tri-Glide which are currently being built. With that said, I attempted to remove the OEM Header Pipe Extension (right side) in order to replace it with 1 that offers more of a drop. I removed the right-side tailpipe and loosen the clamps, but there was no way in hell that extension was going to get past the cross member of the frame. The lip on the header side of the extension is too large (see small circle in pic). I assume I could have removed the entire head pipe, but was trying to avoid that. Is there a trick to removing the OEM Header Pipe Extension?
