Heated Seat Connection
I just received my Mustang heated seat today for my 2022 Tri-Glide, but the seat connector doesn't seem to pair up with the accessory connector in the left side panel. Am I missing something?
1st pic is the seat connector, 2nd pic is the connector under left side panel
Check with Mustang as there might be an adapter cable for the trike. Those are reversed. LOL... Can't really tell about the pin spacing for all the grease in the plug, but it looks like it isn't spread the same. How many pins does the plug have ?
The following 2 users liked this post by aviscomi:
sloufoot (03-20-2023),
Trainerbco (11-30-2023)
Mind if I ask...
Which Mustang heated seat did you buy?
How do you like it? (compared to the original seat)
Is the power switched (i.e., turns off when the bike is powered down)? Or do you have to manually turn the seat off? (and risk a dead battery on those days that you forget to turn the seat off).
Nevin
Nevin
Mind if I ask...
Nevin
Nevin
When I look up that part on YouTube the inside connections looks different, lots of bad info out there.
Ours are 4 pins two on top, 2 on bottom .
The ones on YouTube are 4 by side.
I have exact year triglide with Mustang heated seats & exact problem as you.
Down South
10-30-2019 09:45 PM
