Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Looking for trailer to haul Triglide
Old 11-07-2021, 02:39 PM
cycle7447's Avatar
cycle7447
cycle7447 is offline
Received 1,960 Likes on 1,196 Posts
5Whels - once you got the trike into the trailer - how in the world did you get out.
You must be one of these young guys - I am not the flexible anymore (lol)
  #42
Old 11-08-2021, 06:31 PM
5wheels's Avatar
5wheels
5wheels is offline
I get off of the right side and go out the side door.
  #43
Old 11-09-2021, 06:37 PM
cycle7447's Avatar
cycle7447
Ahhhh. makes sense now. Didn't see your side door
  #44
Old 11-10-2021, 11:16 AM
GaryS1951's Avatar
GaryS1951
GaryS1951 is offline
I just measured the opening on my newer enclosed trailer and have about 64" between cables, the door opening is 65.5". Trailer is a Wells Cargo Road Force 6' X 12' Their older brochure shows a slightly smaller opening.
  #45
Old 11-14-2021, 04:11 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
If you get a six-footer, make damned sure you keep the rear end from moving side-to-side, because if your front wheel is in a wheel chock, and the rear shifts to one side or another, you better be planning on having a way to pick it up and straighten it out before backing up, or you WILL run into the cables.
I had the rear shift about an inch and a half to the right on the way home from Florida to Ohio. With the front wheel in the floor chock, the wheel has to come straight back a foot or so, but to the trike the forks are at an angle, and so the rear end keeps turning further and further to the right. I've got a 7x12 foot trailer, and the only way to get it out was to back up a little, remove the chock, pull forward to straighten it out and then back up. What a pain in the .......
  #46
Old 11-15-2021, 07:36 AM
jetspeed8's Avatar
jetspeed8
jetspeed8 is offline
It needs to be cross strapped in the back to prevent the Trike from moving sideways. Or, use a Biker Bar and that eliminates the problem altogether.
  #47
Old 11-16-2021, 06:33 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Received 4,092 Likes on 3,492 Posts
All the "Biker bars " I have seen you have to be positioned just so , or they won't latch right. A Trike is a bit hard to slide around to make that so.
Much easier to just cross tie the rear to the rings already on the rear of the trike.
The following 2 users liked this post by sloufoot:
5wheels (11-18-2021), IzzoQuazzo (11-16-2021)
  #48
Old 11-18-2021, 07:48 PM
5wheels's Avatar
5wheels
5wheels is offline
Looking in my pic you can see the pool noodles I use or you can use pipe insulation to cover the cables. Just slice them long ways and slip them on the cables. Not perfect but will help with little rubs. Definitely cross strap cause like Oogie says if they get out of line they are a pain to move, especially if you have a chock. And yes I use a Condor as well in the front and tied down.
Oogie Wa Wa (11-25-2021)
IRISHSE
03-22-2013 12:15 AM
DJA
05-28-2010 07:07 PM
avcaruso
12-28-2009 12:15 PM
inthechateau
11-08-2007 01:36 PM
hduc2005
Great Lakes
11
02-22-2007 03:02 PM
Quick Reply: Looking for trailer to haul Triglide
