Dunlop American Elite tire pressure on front tire?
Received 4,197 Likes
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Harley says 36 psi for the stock D402. I don't know why it would be different for the American Elite. Might call or check with Dunlop. I know on two wheelers Harley says more pressure -40 psi. Now running a rear tire reversed on the front I really don't know what is correct or if it should be treated as a front tire or a rear tire. Kevin likes 41 psi (and that is what Avon recommends on their tires) so I's say between 36 & 41 psi.
Tires are designed for the forces that will be applied to them. Reversing a tire has the forces acting opposite to the tires design. Could that cause a problem? Not something I'm going to try. If the tires fails it could be a major failure resulting in a bad situation. If there are injuries or worse you could be at fault when accident investigation shows the tire mounted incorrectly. Your ride your choice.
I have run rear tires reversed on 3 different Tri Glides, for just shy of 100,000 miles with not only no issues, they function better than the front two wheeler tire that Harley puts on the front a a Trike that does not lean like a 2 wheeler.
I would for sure if I could get the av71 but I think all they make now or the AV 91 and that's the one that I've heard and read all the problems that others were having with it so I wanted to try the American Elite. The Avon cobra av71 that I had is still on my wife trike and has over 22,000 miles on it and still look good. So the av71 would have been my first choice if available
azbob09 (04-19-2021)
I just had the Harley dealer that I have been dealing with for the last two or three years put on an American Elite front tire on my bike and we'll see what kind of mileage I get from that . My wife's Tri Glide is still running the AV 71 I just mentioned.
