Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Trike Mid Step
Old 02-26-2021, 09:01 AM
Nokkon Wud's Avatar
Nokkon Wud
Nokkon Wud is offline
Received 1,552 Likes on 844 Posts
Default Trike Mid Step
Got the mid step installed yesterday. The only issue is they shorted me 1 U-bolt but I'll pick one up local so no problem there.
Easy install. Took me maybe a hour including beer breaks and a knee I can't kneel on so I pretty much looked like a beer drinking whale flopping around on the shop floor.
Pricey but in my case they work better than crawling on the trike.
I put the shocks back on. I took them off thinking I'd have the lift kit and 14" PA but apparently they are back ordered. Wish I'd have known.
They did charge my CC first thing though.
flashprez (03-08-2023)
Old 02-26-2021, 09:24 AM
NoKenDo's Avatar
NoKenDo
NoKenDo is offline
Do you know if you can get matching covers for those?
GPHDXLC (09-26-2022)
Old 02-26-2021, 09:46 AM
Nokkon Wud's Avatar
Nokkon Wud
I do not but I'm thinking you can use a HD board although I maybe wrong.
Old 02-26-2021, 09:53 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 4,002 Likes on 2,553 Posts
I put a mid step on my partners trike Sportster conversion
Old 02-26-2021, 10:03 AM
Nokkon Wud's Avatar
Nokkon Wud
I do not but I'm thinking you can use a HD board although I maybe wrong. The boards attach with a rod that goes through them with cotter pins on the ends.
Old 02-26-2021, 10:18 AM
graygoat's Avatar
graygoat
graygoat is offline
Been thinking about these, just seems like a lot of money for the parts you get. I would not need the floorboard or the p-brake extension if the main bar extended out another inch past the folded up floorboard, kinda like a solid peg to set up on. Just thinking out loud here, still undecided.
dptyshrf (03-09-2023)
Old 02-26-2021, 10:49 AM
Longbeard71's Avatar
Longbeard71
Longbeard71 is offline
I made the mount myself order the floor boards from JP cycles. I have around 60 dollars in all of it. Mine is a 2011 so no problem with parking break in the way. They make getting on and off a lot easier.
Old 02-26-2021, 11:26 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 30,871 Likes on 11,605 Posts
That’s pretty good idea. I lost count of how many times I started mine in neutral, then when using the floor board to step up and over, accidentally stepped on one of the shifters. Since I had the rear brake in, it would just lurch and stall. But, was quite scary and embarrassing.
GlidingJoe (02-26-2021)
Old 02-27-2021, 12:56 AM
sloufoot's Avatar
sloufoot
sloufoot is offline
Received 4,092 Likes on 3,492 Posts
One would think after about the second time I did that I would have learned to wait until I was mounted before I started the engine. LOL !! That is as long as it isn't kick start.......
Sorry, but I had to !!!
plumb1bob (02-27-2021)
Old 02-27-2021, 05:31 AM
santajim's Avatar
santajim
santajim is offline
Talking
Buddy of mine that is a welder made the midstep for me and I start my bike before I get on but I get on from the other side or I know I would do that and the bad thing is Mama gets on first so I am sure she would pound the crap out of me if that bike jumped.
The following 3 users liked this post by santajim:
Don60 (09-25-2022), Dr ROK (03-08-2023), plumb1bob (02-27-2021)
Quick Reply: Trike Mid Step
