Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Trike Mid Step
Old 02-27-2021, 06:29 AM
Rogue1's Avatar
Rogue1
Rogue1 is offline
I really like those but they are kind of pricey. I use the passenger floorboard and swing my leg over.
Old 02-27-2021, 06:31 AM
plumb1bob's Avatar
plumb1bob
plumb1bob is offline
I love the idea of mounting the trike easier. I can’t believe that no one else has come up with a inexpensive way to make the midstep.
theheder (07-18-2022)
Old 02-27-2021, 07:10 AM
TOHOG's Avatar
TOHOG
TOHOG is offline
Default Mid Step with HD floor board
HD stock passenger foot boards will fit. I found some take offs a friend had and he gave them to me. If you find some you can save $200 and match what you have.
GPHDXLC (09-26-2022)
Old 02-27-2021, 08:09 AM
GaryS1951's Avatar
GaryS1951
GaryS1951 is offline
I'd like to get my hands, eyes, and tape measure on a set for a few minutes. I know I could make a set way cheaper.
Old 02-27-2021, 08:25 AM
graygoat's Avatar
graygoat
graygoat is offline
Tohog, do you have the p-brake extension on there? I can't quite tell. thanks
Old 02-27-2021, 01:07 PM
Nokkon Wud's Avatar
Nokkon Wud
Nokkon Wud is offline
Received 1,552 Likes on 844 Posts
Mine is a 13 so I didn't have to do anything to the brake.
Old 09-23-2022, 02:08 PM
R4D8 Crew Chief's Avatar
R4D8 Crew Chief
R4D8 Crew Chief is offline
Stage I
Default MidStep
Originally Posted by Longbeard71
I made the mount myself order the floor boards from JP cycles. I have around 60 dollars in all of it. Mine is a 2011 so no problem with parking break in the way. They make getting on and off a lot easier.
got some pictures?
Old 09-24-2022, 08:16 PM
Longbeard71's Avatar
Longbeard71
Longbeard71 is offline
Check my post ready to ride. You can see them there.
Old 09-25-2022, 06:51 AM
Padre's Avatar
Padre
Padre is offline
Received 1,233 Likes on 534 Posts
Originally Posted by Nokkon Wud
Got the mid step installed yesterday. The only issue is they shorted me 1 U-bolt but I'll pick one up local so no problem there.
Easy install. Took me maybe a hour including beer breaks and a knee I can't kneel on so I pretty much looked like a beer drinking whale flopping around on the shop floor.
Pricey but in my case they work better than crawling on the trike.
I put the shocks back on. I took them off thinking I'd have the lift kit and 14" PA but apparently they are back ordered. Wish I'd have known.
They did charge my CC first thing though.
Where did you get the mid step?
Old 09-25-2022, 12:59 PM
Nokkon Wud's Avatar
Nokkon Wud
I got it direct from them but I think maybe DK Kustom Kevin sells them.
Quick Reply: Trike Mid Step
