HD Oasis Day Cover
HD Oasis Day Cover
I am thinking about buying a HD Oasis Day Cover PN 93100028, but I have a question I need to have answered before I purchase it. I installed the DK Tour Pak relocator kit about 2 1/2 years ago. Have any of you in this forum installed this cover with the tour pak moved back? I installed mine with just a 2 inch set back, not 3 inches. Just want to make sure it will still work without stretching the cover too much. I do have the Airwing rack and light installed on the tour pak. Thanks for any help.
****Well not long after posting this I found this info from Sloufoot from a post back in April of 2016.****
Quote: "One thing to be aware of is if you have moved your tour pac back a couple inches the Oasis cover has a real problem stretching over everything.
Because the Oasis cover gets stretched to the limit just to fit right."
So, anybody in here have any recent experience with this? Sounds like with the 2 inch setback and the Airwing rack, I might be out of luck?
Thanks.
BTW, do you have a rack on your tour pak?
