Custom Dynamics Probeam tail lights?
Just wondering if anyone has these on their Tri glide and if so are they happy with them or not .I'm thinking of installing these on mine. I recently traded a 2017 CVO Limited on a tri glide and I liked the LED lights on the CVO but I have never used lights from Custom Dynamics
Thanks in advance for all the input
Terence
Terence
OK, I don't have a Trike. But do Trikes use the same square tail light as a lot of Harleys? I have a '16 RGU and I replaced the OEM rear center tail light with the CD Probeam tail light. Much brighter!
And I have CD filler Probeam lights between my bags and rear fender and have the strobe/flash module for my tour pak lights and have their front turn signals whatever they call them that run a really bright white light till you hit a turn signal then it goes amber through the turn then back to white. I am sold on CD products and service. Really nice and knowledgeable folks to deal with.
Go into the Custom Dynamics link and they show you what the difference will be. Also, if you have the airwing luggage rack, you can add a third brake/running light, just to make you more visible, day or night. The light are very bright. I haven't taken new pictures yet but I am happy with those lights. Cars seem to stop further back than when I ran the stock taillights..
I have them on the Freewheeler. Same light as the rest. Only variations are the license plate lights. The left side for the FW had the clear led lenses on the bottom to light up the plate. The one on the right does not. On a Tri Glide you'd get the ones without the license plate light. They're not cheap. But they're worth it.
