J&S motorcycle jack for a Freewheeler?
Hello All
Has anyone tried a J&S standard motorcycle jack on a Freewheeler?
I would only lift just enough to reposition in the garage...keep it low and not long term.
I've messaged J&S just now but was wondering if anyone has done this?
Many thanks
Dante
Many thanks
Dante
I have a Craftsman motorcycle lift. I bought it when I had my Dyna. I have used the lift for my FreeWheeler. Since there are stops at different points on the lift, once engaged, they will stop any freefall should the hydraulics fail for any reason. I have used this lift to reposition the trike in the garage and left it in the raised position for extended periods of time. The craftsman lift is rated at 1000 lbs. Can't really answer about the J&S jack. They should be close in ratings. This is not legal advice. Use at you discretion.
Dante221 (01-16-2019)
talkingrock (01-19-2019)
IndyRider
07-13-2006 07:08 AM
