Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Making a reduced throw lever (What do you think)
Old 11-09-2018, 11:47 PM
lee123's Avatar
lee123
lee123 is offline
Default Making a reduced throw lever (What do you think)
Has anyone ever applied heat - to bend a Harley clutch lever - thus bringking the lever angle closer tho the handel bar ? (reduced throw)
I know there are products out there, but this processs seems so simple, and I only want a one inch change.
You tube demonstrates, Easly bending Aluminum. What do you think ?
Old 11-09-2018, 11:54 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Received 4,092 Likes on 3,492 Posts
Before you make that much of a change in the travel of the clutch lever take something 1" thick and place it between the clutch lever and the grips and see if it will still let you work the clutch correctly.
Old 11-10-2018, 12:33 AM
lee123's Avatar
lee123
lee123 is offline
good idea... Just checked. No problem. thamks
Old 11-10-2018, 07:07 AM
santajim's Avatar
santajim
santajim is offline
If you do this please let us know how it works out I have short fingers so I am interested to see if this is doable.
Old 11-12-2018, 04:03 PM
harrell42's Avatar
harrell42
harrell42 is offline
I dont think you would have enough lever travel to adjust the clutch properly
roller
Old 11-13-2018, 10:57 AM
BilltheDiver's Avatar
BilltheDiver
BilltheDiver is offline
6th Gear
There is a reduced throw clutch lever by SoftBrake that does exactly what you describe by reducing the distance between the handlebar and the lever by 1 inch. If it works for that, I don't see why yours wouldn't work.
vegas-triker (11-19-2018)
Old 11-13-2018, 11:55 PM
lee123's Avatar
lee123
lee123 is offline
Default The lever does bend (see you tube on bending)
Worked our\t fine.
Works fine
Two different heatings and bendings - but ended up just as I wanted.
Cagmo (11-14-2018)
Old 11-19-2018, 04:25 PM
vegas-triker's Avatar
vegas-triker
vegas-triker is offline
Made the mistake, called and talked to the owner of SoftBrake... I have been wrong for all this time... when asked, I always say the first things that need to be done are bumper, lift, and LED's...nope, these are now top of the list.. WHAT A DIFFERENCE !! my fingers and wrists say "Thanks !"
Old 11-20-2018, 09:50 AM
Cagmo's Avatar
Cagmo
Cagmo is offline
Yes, Softbrake worked well for me.
vegas-triker (11-20-2018)
Old 11-24-2018, 08:34 AM
sfchief's Avatar
sfchief
sfchief is offline
My wife is also a Softbrake fan on her 2018 trike.
BigDogIdaho
Milwaukee Eight (M8)
172
05-08-2018 10:35 AM
Big Gonzo
08-02-2017 08:28 AM
WG2011
03-31-2015 09:24 PM
rquest
11-30-2012 10:07 PM
Bankrupt
Exhaust System Topics
04-11-2011 05:36 PM
Quick Reply: Making a reduced throw lever (What do you think)
