Screaming Eagle Pipes
wengerda (08-24-2018)
I have installed new pipes on my Trike and a friend's. We had the same issue initially and just needed to adjust the crossover pipe and placement of the two to be even. We ended up using a long level set across the ends of the new pipes to make sure they were even with the back end of the bikes (bumpers, in each of our cases) and adjusted the distance before tightening. If I remember right, it was easiest to tighten the bolts on the top of the pipes and tighten clamps working back towards the header to make sure nothing moved after getting them in the right position.
I hope this helps.
I hope this helps.
I hope this helps.
I hope this helps.
Actually glad to see this thread - I’ve ordered the SE pipes and have installation scheduled for next week. Will certainly mention the rear exhaust alignment in advance and check it when complete.
strych9 (08-24-2018)
