Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Front wheel bearings
Old 01-28-2018 | 09:31 PM
hardheaded's Avatar
hardheaded
well, when you install these bearings you need an installer that will support both the inner and outer races. this is not importent when installing the first bearing, but when installing the second, you do not want to just support the outer race as the inner will make contact with the inner wheel spacer first and then as you keep pushing you are side loading that bearing again. the correct tool supports both the inner and outer together .when that bearing just makes contact with the inner wheel spacer, it's time to stop. hope this makes sense !
check service manual for which bearing goes in first to be seated.
Seahorse
04-04-2019 07:49 PM
bradleys
05-17-2018 10:20 PM
dbrow6272
General Topics/Tech Tips
05-07-2017 07:35 AM
bigheadted
03-29-2015 09:48 PM
falconbrother
EVO
13
05-03-2014 05:58 PM
Quick Reply: Front wheel bearings
