Push the pedal all the way down and let your foot slip off the pedal and let the pedal slam up. I had the same issue and this is how I fixed the issue. Hope it works. Jim
Push down on parking brake lever but it won't stay down and catch
Had a little trouble with the parking brake on my 15 TG. Used a little WD-40 and worked it briskly several times. Haven't had a problem since and I use it all the time. Make sure you lube the ratchet on the brake.
