Installed Stealth External Breather
Received 4,234 Likes
Been fiddling with the Stealth EBS for a while on the Tri-Glide.
Yesterday, finally decided how I wanted it.
Got the tubes connected under the tank, and then routed along the existing coolant hose, down the front and to a filter below the right floorboard.
Made sure the filter was higher than the lowest thing on the bottom.
Standing beside the bike you can't see the filter...unless you squat down.
mctraveler (03-16-2019)
Yes, it is likely to get dirtied up with road grime, especially while riding in the rain. But it will not get so clogged up that it will impede the flow of air out the breathers.
It is out of sight, and the nice thing about the filter is, whenever the bike is washed, so is the filter. No need to remove it...just spray it with some soap and then spray it off with the hose.
Kevin
An External Breather System (EBS) can be installed on a S/E Stage I, and it will enhance your performance and engine longevity.
It is a bit different model than the one I installed on mine above, but it can look similar that the end, and will function the same.
The one that will work on your A/C can be seen at this LINK.
Kevin
Kevin
Kevin
Kevin
I will order one as soon as I get your part #
DK Custom - ST (11-29-2017)
I am thinking of using this EBS on my 2018 Road King. The kit only comes with 2 feet of hose. I want to run it along side the gas tank over-flow line which runs down the left side of the bike and then back behind seat and down to the ground. Can you make a kit that has more hose than 2 feet?
