Volt meter jumping back and forth
I installed a Cycle Electric rectifying voltage regulator .I noticed after I ride for a while the needle on the volt meter jumps between 14 &16 volts constantly .The H.D. voltage regulator is designed to dump voltage to ground while the C.E. regulator is suppose to produce only voltage needed .My question is does this seem normal for a rectifying regulator ? Any knowledge on this is helpful.
Received 4,212 Likes
On my 2011 the volt meter was pretty stable.
On my 2014 Tri-Glide, at 2800 RPM & higher, the needle moves like a jumping bean between 12.5 and 15 constantly.
I have had it in numerous times, to different dealerships. They all say it is within spec, and have showed me other bikes that do the same.
Most importantly for me, this has been going on since it was new and 3 years and 50k miles later, I have had no electrical issues (other than I don't like how the needle bounces around), so while not preferable, it does appear to be normal/ok.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
Muffbrorick (09-12-2017)
Hmmmm.
Well i don't know the answer either, but here is a thread that at the least is interesting!
https://www.hdforums.com/forum/touri...r-jumping.html
usmc68 (09-14-2017)
usmc68 (09-14-2017)
HDPursuit
Electrical/Lighting/Alarm
08-22-2018 12:56 PM
