Front fender
Received 4,228 Likes
The emblem has two pins that go thru holes in the fender. There are sheet-metal thickness retaining clips that go over those pins.
The clips may have come loose and you can put your fingers up in there and push them tighter on the pins...or you may have lost one and need to get a replacement and push it up onto the pin, tight against the inside of the fender.
It's not a very secure design. I have a loose "Tri-Glide" script emblem myself right now. It is only being held on by one of the pins...I need to get another clip and put it on.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
