Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Heated Gear Using Battery Tender
Old 10-28-2016 | 09:10 PM
WestRoadHarley's Avatar
WestRoadHarley
Default Gerbing 12V Accessories
Gerbing makes a heated gear "Port kit" that connects right to the battery. The port is a mounted connector that I put on the left side wind deflector right in front of the seat. The port comes with a rubber plug to protect it when not in use. The installation is easy, once you get by the drilling a hole in the deflector.
Old 10-29-2016 | 09:59 AM
nhrider1's Avatar
nhrider1
Originally Posted by captbob
+1 on that recommendation from First Gear. I talked directly to the owner/manufacturer and he said the same thing. He supplied me with a separate fused heavier gauge wire that is separate from the Battery Tender wire and are compatible with my Harley Tri Glide and other wiring.
That's the correct action. The fuse is there to protect the wiring and is rated accordingly....so adding a bigger fuse to the Battery Tender leads isn't a good idea. You may get away with it if the current draw isn't too bad, but you're defeating the safety ratings.
Running heavier gauge wiring directly to the battery (with or without a switch)with an appropriately rated fuse is the correct solution.
Reference the table below:
Remember, these are the recommended maximum fuse ratings for the corresponding wire sizes. If you are using wire sizes smaller than the reccomendations with a larger fuse, there can be problems. However, using a smaller fuse than what is reccomended is the way to get an efficient system. Small fuse, big wire is always most safe.
Last edited by nhrider1; 10-29-2016 at 10:30 AM. Reason: Table didn't print correctly
Old 10-29-2016 | 10:18 AM
TriGeezer's Avatar
TriGeezer
Maybe they changed the wiring for later model battery tender pig tails. But, my '12 and others I have seen the tender pigtail connects directly to the battery, and has an inline 7amp fuse.
woodmnctry
2014-2023 Touring Models
11
12-06-2019 07:45 PM
Global Cooling
14
04-29-2014 02:44 PM
nivensid
11-02-2012 03:52 AM
brgtr3
Product Reviews
03-02-2010 05:18 PM
jimmers1817
Electrical/Lighting/Alarm
10-29-2008 02:37 PM
Quick Reply: Heated Gear Using Battery Tender
