DK tank lift question
I lifted the front of the tank with the DK 1.5" lift, no lift in the back and do not notice anything on the seat nose angle. Probably is a very slight change but not noticable to me. I do have less buffeting with less air over the top of the tank. I can't speak to any higher lift than the 1.5". I'm sure others will chime in here that have a higher lift.
DK Custom (04-18-2016)
2" lift old shiney
I went to the 2" lift deluxe raised rear of tank 1/2" to get rid of glasses dance works great for me actually suppose to get more air on motor to run cooler twin cams need all the help they can get . looks good easier to clean rocker covers as a plus. would like to see what 2 1/2 would look like. Seat hooks in fine actually very flexible in front horn portion. ride safely fearless
2" lift
I put the 2" on a '10 FLHXXX and had a problem with fitting the front tongue Went to the Hardware and purchased 3/8 tall spacers for the tanks rear. This cured the problem. Now I changed the stock bar to the 10" Twin Peakes and can't use the lifts. All I have now is a 1.25" clearance between tank and bars. Really did like the looks of a lifted tank.
Received 4,198 Likes
Tank Lifts, one of those little things that make a difference!
I ran a 2" on my '11 and am running a 1.5" on my '14.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
