tour pak lid tether
Received 49,976 Likes
OK, so I deleted the pics. Basically this stuff:
I drilled holes pretty much centered on the lid behind the (removed) seat back, and on the bottom centered about an inch and a quarter down from the edge. Then I used two fender washers with 3 layers of black electricians tape on their inward side for padding, and a #10 stainless flat head screw and nuts to secure the ends of the chain. Kind of like this:
It's has just a little slack when the stock tether, which remains, is at full extension.
Prevents overtravel, doesn't tangle or hang up with anything, and has worked well in the first 1500 miles of our trip, no issues whatsoever.
I'll take more pics when I get home.
Hope this helps someone.
Edit: oh, yeah lots of blue Locktite.
Edit2: The stuff is fairly flexible without much loss of strength, so to open the openings big enough for the screw to go through, I just used a tapered drift through them on a partially open vice. Neither one interferes with the seat back, there's clearance there. The fender washers on the inside are larger diameter than on the outside, well, because that's what I had. Also, being centered lets the chain hang down into the tour pack when closing it, so it never gets in the way of closing. I thought I might have to space out the top further into the pack with some extra washers for that, but it wasn't needed.
All that, and later when I have time I'm going to reinforce the inside of the hinge area where the screw heads are with some metal strap and some JB Weld to spread the stress out over more surface area. Occasionally we had to open the tour pack with a 20 pound duffel bag still on the lid; and although I held it carefully while the wife put stuff in and out, I could feel it trying to flex a little. That way if anything happens it'll at least have a chance not to tear the hinges out of the top or the bottom.
Missionwop, where did you get the stronger hinges?
Received 5,459 Likes
