60 Mph @ 2,500 RPM
60 Mph @ 2,500 RPM
Can anyone tell what pullies I have 32 or 30 on front 6th gear on the level 60 mph at 2,500 rpm. I'm just wondering it seems the longer I use 360 additive smoother ole Shiney runs. ride safely fearless
IF your trike is stock, you have a 32. '09, and '10 trikes came with a 32 tooth sprocket. They changed it to a 30 in '11. Take a look at the 'sticky threads', young Mike (msocko3) did a great article on changing the gear.
With the 32 you get a tad more top end and a smidge better gas mileage. The 30 gives you miniscule better acceleration and better use of 6th gear. It is a toss up. For years I rode an '09, wife had an '11. Really didn't make that much difference.
Checked speedo with GPS
Well I believe I'm back to square one it seems there is a five MPH difference between GPS and speedometer is five MPH slow. So now where is the gearing sounds like I still have a thirty two tooth cog on front? This winter I will paint one tooth and count thanks all opinions appreciated. 6th gear at 65 MPH 2500 RPMs
corliss@bakerdrivetrain.com
11-15-2017 10:42 AM
