Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Freewheeler rear brake question
Old 04-11-2015 | 02:04 AM
missedem's Avatar
missedem
Default Freewheeler rear brake question
I am currently experiencing rear brake issues with my freewheeler. Bike is up at the dealers to be fixed .
They have tried everything and when using the rear brake (which is linked to the front) the back right rear wheel locks up badly and pulls the bike to the right.
Technically since the front and rear brakes are linked via the rear brake pedal they should not do this. Also locks up enough to smoke the rear tire. The demo model that they had just started doing it as it got more miles on it but not nearly as severely. Apparently mine locks up pretty badly compared to most.
The HD tech people were called and ideas were exchanged . So far a solution has not been found. Was told the main HD corporate head trike tech guy retired recently. My question is:
Has anyone else experienced this problem and if so . How did your dealership fix it. ?? Thanks for your time.
Old 04-11-2015 | 02:19 AM
RiverB's Avatar
RiverB
If I nail the brake pedal on my Tri, the right rear locks up first. I don't consider that a problem, just behavior I need to be cognizant of.
My emergency braking protocol involves pedal and lever.
I don't like your signature. Sue me.
Old 04-11-2015 | 02:29 AM
missedem's Avatar
missedem
The freewheeler has linked brakes , which mean the rear brake pedal operates both front and rear brakes simultaneously. The lead mechanic at the shop I go to and Harley them selves have told me there is no way the bike should be locking up like this.
I always use front and rear brakes and both front lever and rear brake pedal to emergency brake. The problem lies in that my rear tire locks so hard when I use the rear brake the tire smokes and bike pulls hard right so I cant use the rear brakes to slow in a turn and on the trike that is where my main braking source is. And it does not take much to do this. Harley told my shop to tear the rear end apart and check it out . They have done so. They just cant figure out how to get the brakes to work properly. I was looking for possible solutions to fix this or see if any one else had experienced this problem. I do appreciate your input. In my particular case its not just that the trike is doing this but how badly its doing it.
Old 04-11-2015 | 02:39 AM
RiverB's Avatar
RiverB
Yeah, how badly is subjective and therefore hard to deal with. Hope you get resolution. All I can offer is that my right-rear locks up first, too. I appreciate the predictability.
Old 04-11-2015 | 02:49 AM
missedem's Avatar
missedem
And I appreciate you taking the time to offer input ...thank you.
Old 04-11-2015 | 06:50 AM
Springman65's Avatar
Springman65
Originally Posted by missedem
I am currently experiencing rear brake issues with my freewheeler....... ....... Has anyone else experienced this problem and if so . How did your dealership fix it. ?? Thanks for your time.
Well, I have a 2015 Freewheeler and I am glad to report that I have not had this experience. However, if I do, you will hear about it, I promise.
I have limited experience on my FLRT, still under 2K miles on it; but, I have learned that when I do break, I always apply the rear first and then the front - totally opposite of the way a was generally breaking on two wheels - so, I understand your dilemma.
I hope you can get this resolved and quickly.
Springman
Old 04-11-2015 | 07:05 AM
paw paw willie's Avatar
paw paw willie
Have 10,000 on my Free. Never had this problem.
Old 04-11-2015 | 10:21 AM
screwball's Avatar
screwball
Nearly 6000 on my Free and no problem. Good luck and keep us up to date.
Old 04-11-2015 | 10:58 AM
screwball's Avatar
screwball
A thought. Waaaaay back when as a kid I used to have problems with my old 1950 Ford. If I hit the breaks hard it pulled hard to the left. Problem was the RIGHT rear break cylinder. If your right rear is locking up, could be that your left rear isn't doing it's job, you stomp harder and lock up the right. There is a differential valve that puts about 70% break to the front. I'm definitely not a mechanic, just speaking from experience.
Good Luck!
Old 04-11-2015 | 11:25 AM
Frostbite's Avatar
Frostbite
Good Luck!
My thought too. Was thinking pinched or kinked brake line to left wheel. But if HD tore everything apart they should have caught that.
Quick Reply: Freewheeler rear brake question
