Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
seat screw
Old 01-01-2015 | 06:29 PM
coronetracer65's Avatar
coronetracer65
Default seat screw
Anyone else have problems with the seat retaining screw ? I bought a sheepskin which requires seat removal to install. Ha it is bad enough trying to get that damn screw in without an added cover. Thinking about putting a stud in its place and making an extended nut for it ! Any ideas are welcomed ! Ebert
Old 01-01-2015 | 06:39 PM
BinIdaho's Avatar
BinIdaho
I also have a sheepskin cover over seat.....just went with a longer screw.
Old 01-01-2015 | 06:45 PM
FuzzyWuzHe's Avatar
FuzzyWuzHe
I like the stud idea ... although I wonder would it be tougher to get the bracket over the stud.
Old 01-01-2015 | 07:11 PM
Mr.Softy's Avatar
Mr.Softy
I don't have any problem seeing where the screw is. I pull up the back of the seat tucking it into the TP and the screw is pretty visible. I hold the seat pulling up as I unscrew the screw. Installing the seat I have the screwdriver set in the screw in the seat and hold the seat up off the mount until the screw starts. Maybe I am missing something here?
Old 01-01-2015 | 08:08 PM
Casper's Avatar
Casper
We have a 14 TG and it's the biggest pain in the butt to put that darn seat screw in....never had any issues with earlier years....
Old 01-01-2015 | 08:16 PM
screwball's Avatar
screwball
I took out the phillips screw and replaced it with a thumb screw
Old 01-01-2015 | 09:13 PM
TrapshooterBob's Avatar
TrapshooterBob
I did the tglidestuff.com tour pak relocation. With the pak back 1.5" the screw is really easy to get at.
Old 01-01-2015 | 09:25 PM
sullyj020's Avatar
sullyj020
I went to Home Depot and got a screw with a ****, don't need the screwdriver now.
Old 01-01-2015 | 09:44 PM
FuzzyWuzHe's Avatar
FuzzyWuzHe
I use a foresps (-5 sp) last time to get the screw in ... locked on ... use it to get the screw started then used a long phillips to tighten it ... not perfect but worked ... I'm gonna do some playing with the stud idea
Old 01-02-2015 | 04:00 PM
Lilman's Avatar
Lilman
I put a stud and stainless, knurled thumb nut on mine. So much easier!
