Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
2015 Freewheeler FLRT - baffle removal
Old 10-02-2014 | 03:39 PM
Eric Severing's Avatar
Eric Severing
Stage I
Default 2015 Freewheeler FLRT - baffle removal
Have always found these forums useful. Just picked up this new ride yesterday. For those waiting for better exhaust options, a 2" bore bit is a perfect fit to remove the stock baffle.
Old 10-03-2014 | 01:12 PM
Tjackson's Avatar
Tjackson
Default Baffels
What is a bore bit?
Old 10-03-2014 | 02:42 PM
hedgie57's Avatar
hedgie57
I believe it's a hole saw
Old 10-03-2014 | 04:12 PM
firefighter616's Avatar
firefighter616
What's it sound like now, just right or too loud?
Old 10-04-2014 | 06:56 PM
Hard Ride's Avatar
Hard Ride
With the FW I would replace the headpipe first to decat ...
Old 10-05-2014 | 10:32 AM
DK Custom's Avatar
DK Custom
Platinum Sponsor
You may find that you like the stock exhaust with the baffles removed and W258 Thunder Torques installed. Whopping $25 and will probably give better performance than any aftermarket slip-ons you can buy.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 10-05-2014 | 11:07 AM
Tjackson's Avatar
Tjackson
Kevin,
What are w258 thunder torques, and where do they go? Is this one of your products?
Thanks,
Tracy
Old 10-05-2014 | 11:55 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Originally Posted by Tjackson
Kevin,
Thanks,
Tracy
Yes, this is one of our products. It is a patent pending insert that is installed in the exhaust, with or without baffles. It reduces engine pumping loss & increase exhaust gas velocity. This results in more power at the rear tire(s).
You can see more details, videos, and dyno charts at this LINK
Old 10-06-2014 | 11:49 AM
Tjackson's Avatar
Tjackson
Kevin,
I'm thinking of using them on a '14 tri with stock mufflers (baffles and cat removed). So these go inside the rear of the muffler and are held in place with a bolt? I can't see them in the video and it's hard to tell in the packaging. I think that on the stock mufflers the baffles are welded in.
Thanks,
Tracy
Old 10-06-2014 | 10:30 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Kevin,
Thanks,
Tracy
Hey Tracy,
I'm on the road right now...but it's a pretty easy install. You can email the shop and they can send you the instructions, or give a call and Dawn or Devin can walk you thru it.
Quick Reply: 2015 Freewheeler FLRT - baffle removal
