Love mine!!! Their shop is about 20 miles from me. I called them up and ordered my jack. Next day I drove up there and they had it assembled and they lifted it into my Jeep. Great guys. Keep in mind that it is a small shop and with COVID there may be delays.
I purchased one when I bought my 2018 TG (new). Though in 2018 the brothers were not all that well organized at the time after some delay the jack arrived, but minus the actual jack. They promptly shipped the jack and with a couple of bolts all went well. I have used the air jack hundreds of times since. Late last fall, almost three years after purchase a small cable connector broke off. I phoned for a replacement part and they asked for photos. Within an hour I got a message that they would replace the entire lever mechanism! Soon after I received the new assembly and with four bolts it was 'like new' again. NO CHARGE!
It appears that over the years they have really got their act together. I HIGHLY RECOMMEND THEM.
BE SURE AND TELL THEM THE YEAR OF YOUR TRIKE! Ones built for pre 2018 do not fit on those 2018+
Interesting about the model year, What is diff on the trike that changed requiring a change to the jack I wonder...
Also I see you have your J&S set up like I and go in from the left side of the trike, yet watching the video on the J&S web site they have it reversed and go in from the right side..
The J&S jack for two wheel motorcycles goes under the bike from the right side. On the trike it goes under from the left side. The trike jack has a small jack pad that the cables attached to the handle raise and lower to lift the trike.
Yes in the videos on J&S Website it shows Trike jack entering from "high side" (right side). I don't remember why they had to change sides but if I remember correctly they said it was because a change in the bike's frame or exhaust pipe location. In any case What they sent me works for mine as you can see.
They are friendly folks to speak with, give them a call and you will get best info.
