Can you recommend good highway pegs?
Hi Gerry, we'd like to recommend our Adjustable Highway Peg Mounts. Available in black or chrome, they are a revolutionary solution to the challenge of adding comfortable highway pegs on a bike with fairing lowers. We started at the motorcycle frame and then worked our way out. The result is the strongest, cleanest looking, and most practical highway peg mount ever. The Adjustable Highway Peg Mounts are fully adjustable and designed to replace the stock floorboard mounts as to not interfere with the bikes lean angle.
Check them out here: https://www.ciro3d.com/product/60100...d-highway-pegs
__________________
I'm pretty happy with these Kuryakin Switchblades on the longer Harley crash bar mounts, I got short legs. Lots of ways to put your feet on them. Or even the back of your ankles for a real stretch.
A lesson learned; don't point any pegs straight out for looks. Angle them back towards you to keep your foot from wanting to slide off the end; vibration will do that. Basically point them perpendicular to your hip or inward slightly more.. Likewise angle them slightly downwards towards the trike, too, for the same reason. Otherwise it can be a struggle keeping them underfoot, which kinda defeats the purpose.
That and if it turns cold, if you hold your legs inward you can actually get the radiator outlets to warm your ankles!! Now if I could just port some of that heat to the inside of a rain suit.......!
