PM Contrast Cut Wheels & Brakes - 21/18 & Single Side Rotor Set Up!!!
Nothing more than a bearing swap. About $30-$45 per wheel.
And for what it's worth, I don't know the seller, never spoke to him in my life. But I recognize a good, quality set of wheels. The two wheels by themselves, minus the rotors, tires, and caliper, is less than retail. Add the rotors, the caliper and tires, and you'd be up another $1200-$1400 easy. Depending on where you buy new wheels from, you could pay damn-near his asking price, just for the front setup, alone.
Plus, add the wait time when buying new... enough to make you crazy. These sound like they're laying in his garage, waiting to ship out today. That's just another plus!
From what I've gathered the fitment goes as follows.
1. 2002-2007 touring; direct fit
2. 2008 touring you will have to change out the wheel bearings to 3/4"
3. 1996-2001 touring, again a simple bearing swap
Hope this helps a bit. Also, don't forget I also have included the matching air cleaner faceplate!
Actually, they're much larger than 3/4" ID, and they're metric... they're 25mm. Which equals about .98425 inches (ID = inside diameter of the front wheel bearings).
