Road glide turn signals massive audio amp
Take off road glide signals with smoke smooth lenses in good shape $50 shipped massive audio nx2 amp will fit on top of radio in road glide fairing. Great amp I ran 4 6.5" speakers off it for one season. Just upgraded to the 2 new massive audio 4 channel amps. Lots More power and better sound the Rockford 300x2pbr amp I had before. scratch on top but works fine $70 shipped. Paypal only and shipping to us only
Massive Audio NX2 Nano Block Series 2-Channel Car Amplifier
RMS Power Rating:
4 ohms: 120 watts x 2 chan.
2 ohms: 240 watts x 2 chan.
Bridged, 4 ohms: 480 watts x 1 chan.
Max power output: 480 watts x 2 chan.
MOSFET power supply with high grade switching devices
LED power/protect indicators
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies and endless possible installation scenarios
2-Channel operation
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink are anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Adjustable high-pass filter (50-750 Hz, 24 dB/octave)
Adjustable low-pass filter (50-750 Hz, 24 dB/octave)
Subsonic Filter (50-750 Hz, 24 dB/octave)
Frequency response: 10-25,000 Hz
THD (Total Harmonic Distortion): >1%
Signal-to-Noise Ratio: 100 dB
Max Voltage: 15V
Max RCA Voltage: 5V
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
CEA-2006 compliant amplifier
Also found as:Massive Audio SKUNX2
Weight: 12 lbs
Dimensions: 7-1/4"L x 5-1/2"W x 2-1/8"H
1-year Sonic Electronix warranty
RMS Power Rating:
2-Channel operation
Max Voltage: 15V
Max RCA Voltage: 5V
Weight: 12 lbs
