Dual Halogen Headlight Bulb
I have a take off Dual Halogen Bulb from my 2014 SGS...it comes with the two bulb connectors on the back (they were cut off but can be easily wired into your wiring system...see photos).
This should fit many other years, but it is up to you to verify fitment before you purchase.
I am asking $90 plus shipping. I can accept a check (has to clear before I ship), money order, or Paypal (if using Paypal please include an additional 3% of part cost plus shipping to cover their fees)
I think the newest bikes (ones with the Daymaker and new Dual Halogen) have a new mounting plate. The older style headlight bucket needs to be changed. The part number for the new ring is 68124-04B Kutter has it for $41....you would probably need that ring if you upgrade to any newer headlights, such as Daymaker, Dual Halogen, or the Trucklites. You would need to make a simple splice in your wiring, or buy an adapter cable. I did the splice (since I went from the new connector to the old style which is what the Trucklite needs). You would be going the other way...your connector (I believe) has a black, yellow and white wire. You simply use the black as ground, the yellow is your low beam which splices to the blue/yellow wire on the new bulb, and the white splices to the blue/white wire. If you look at the photo I included, you can see the two connectors with the wires I am talking about. It is really easy, and costs nothing to do. I think the connector is over $20 or so. I thin k the upgrade is well worth it, and actually, it probably takes more time to write about it than doing it! If you need any more info, get back to me...I will help if I can. If anyone else has more info, or sees I made an error here, please let me know...I'm working from memory.
