plug and play with all wiring and harnesses? failed to ask....this fits 06 and up right? mine is 11
Yes it should fit yours assuming you have a "batwing" fairing. The install is a little more than plug and play. You will need to get power to the AMP. I ran a heavy gauge power wire from my battery under the tank into the fairing. Might have been overkill but it seemed like the right thing to do.
Once you have power is a fairly straight forward install. You unplug the stock speaker wires from the speakers and connect them to the high level inputs on the amp (I will mark them). Then you plug the speakers wires from the amp into the included ARC speakers that you installed in place of the stock speakers.
The amp is held on with heavy duty velcro. There is already some on the bottom of the amp and I will send the other pat that you attach to the top of the stock radio. Once all the cables and fairing are back in place its a very solid mount and will not move around.
If you have any experience with installing car stereo equipment this is a peice of cake and sounds fantastic.
Let me know as soon as you can if you want it because I have another member that only wants the amp and I am trying to let him know something today. I would really like to sell it all together but if you aren't going to take it then I need to separate it for him.
