Centramatic Wheel Balancers - $175 (Corpus Christi)
Sold!!! Sold!!! Sold!!! Centramatic Wheel Balancers - $175 (Corpus Christi)
I have a new in the box set of Centramatic 200-200 Wheel Balancers for Harley Davidson motorcycles. These low profile balancers will fit all FLH models from 2000 and newer. Retail on this full set of balancers (2 front & 1 rear) is $289. These are active balancers that have a bearing system that is suspended within a proprietary fluid that balances the tires as you ride eliminating the need for any weights on your spokes or rims.
Having the wheel & tire constantly being balanced will reduce the heat buildup in the tire which is it's greatest enemy. Heat = tire breakdown so the cooler that you can keep your tire the longer the tire will last. I had these on a previous bike and can say that they run smooth as silk and extended my tire life by probably 40%. Give me a call (361) 332-1829.
Ron
Ron
I don't have a micrometer available to check the exact thickness, but I was able to put my others on without shimming the brake caliper if that's what you're asking for.
Ron
Ron "Gunner" Retzlaff
02-25-2014 10:43 AM
