Arc Audio Amp and Speakers
Everything works great, adding more speakers and need more channels. been using this setup with 1 set of speakers for 3 years. Amp has a minor rub mark from wiring harness loom rubbing against it but does not affect performance in any way. i have 2 sets of speakers that i will sell if you want it all or just 1 set with the amp. See specs for amp and speakers below.
275.00 plus shipping for 4 speakers and the amp
230.00 plus shipping for 2 speakers and the amp
will post pics later today
1 x Arc Audio 2 channel Amplifier
4 X Arc Audio 6.5" Fairing Speakers
Amp = ARC KS 125.2 mini
Power @ 4 ohms 2 X 70 watts
Power @ 2 ohms 2 x 125 watts
Power @ 4 ohms (Bridged) 1 x 250 watts
Signal to Noise 92dB
THD .05%
Frequency Range 20k – 20KHz
Crossover Butterworth (5Hz – 550Hz)
Bass Boost 15dB 45Hz
Fuse
Size 8.25(L) x 4.8” (W) x 1.7”(H)
Speakers = ARC KS 6026 Coaxial
Rubber Surround Injected molded poly cone
Low Distortion linear suspension
Hi Temp Voice Coil
Stamped Steel Basket
Silk Tweeter
Swivel Tweeter Diameter
MAX Power Handling - 175 Watts
RMS Power Handling- 50 Watts
Frequency Response- 60Hz - 20KHz
Sensitivity 86dB
4 ohm Protection PTC
THD .05%
Fuse
Hi Temp Voice Coil
Silk Tweeter
Sensitivity 86dB
Is this still available?
Thanks
Thanks
THD .05%
Fuse
Hi Temp Voice Coil
Silk Tweeter
Sensitivity 86dB
THD .05%
Fuse
Hi Temp Voice Coil
Silk Tweeter
Sensitivity 86dB
