Harley Touring LED Headlight AND Driving Lights
Old 09-28-2012 | 05:29 PM
JCarver05's Avatar
JCarver05
Default Harley Touring LED Headlight AND Driving Lights
Traded my Ultra on a CVO ROad Glide, so am selling my LED headlamps. They have about 6 months use on them. I paid over $900 for the set. These are plug and play on any HD Touring model 1994 and newer.
Here are the part numbers right off of HD's website.
$500 firm. Cash or paypal only please. Email JCarver05 @ Gmail.com for more info ( remove spaces ) --- ******** I do not check forum daily so please email for fastest response
Daymaker LED Headlamp and Auxiliary Lamps
Cut through the night. Harley-DavidsonŽ LED Lamps are brighter and whiter in color and provide a superior light pattern over standard incandescent lamps. Compared to the yellow light of a traditional halogen bulb, the LED lamp produces a "Daylight Color Impression" that appears more natural to the user. Headlamps feature 2 horizontal "D" shaped lenses that focus light into a pool in front of the motorcycle, and separate high beam and low beam projector lenses that provide a focused beam of light in front. 4" LED Auxiliary Lamps feature 3 "D" shaped lenses that focus the light, and provide a matching appearance to the LED headlamps. The solid-state LEDs are designed for long life, and the shock- and vibration-resistant lamp assembly mounts into existing light housings. Installation is quick and easy, and the plug-in lamps connect to the factory headlamp wiring. No external ballast or complicated wire harness is required. The LED lamps are DOT approved for use in all 50 states.
LED Headlamp Illustration
This product is available in multiple variations. Be sure to look for the one that fits the specific model and year of your motorcycle.
73390-10A
7" Lamp
Fits '12-later DynaŽ FLD, '94-later Touring and Trike models (except Road GlideŽ), and '94-later FL SoftailŽ models equipped with the Headlamp Nacelle Kit. Kit includes mounting ring assembly. Gloss black lamp includes black bezel. Touring Black Headlamp Trim Ring P/N 46555-03A is available separately. '06-'10 FLHTCUSE models require Harness P/N 71628-04 for installation.
MSRP US $524.95
73396-10A
Auxiliary Lamps (set of 2)
All models with a 4" round auxiliary forward lighting. '04-earlier models with auxiliary lamps equipped with spade connectors require separate purchase of Adapter Harness P/N 68355-05 (qty 2).
MSRP US $384.95
So, a good deal! One light has a slight blemish that you can only see when the light is lit, and only when staring right at it. 99.8% of the time you cant see it
Old 09-28-2012 | 09:26 PM
cruzmisl's Avatar
cruzmisl
What light is the blemish on? Can you explain what it is?
Old 09-28-2012 | 09:35 PM
davidw221's Avatar
davidw221
I'm interested PM me, thanks Dave
Old 09-29-2012 | 08:55 AM
patriot2500's Avatar
patriot2500
Fwiw these lights are so worth it. I have them on my RK and they make a huge difference. Free bump for you!
Old 09-29-2012 | 09:31 AM
JCarver05's Avatar
JCarver05
The bottom pic, its about 1 half inch or so
its on one of the side lights
like i said, you can barely see it at all, but when the lights are actually ON it is visible from the right angle--- hence the pic
Old 09-29-2012 | 09:33 AM
JCarver05's Avatar
JCarver05
PM Sent!
Old 09-29-2012 | 09:34 AM
JCarver05's Avatar
JCarver05
Ha ha thanks!
You should see the new ones on the roadie cvo, they are AMAZING
I love the light up HD logos, they are just cool as heck
Old 09-29-2012 | 12:43 PM
JCarver05's Avatar
JCarver05
SOLD SOLD SOLD
thanks HD Forums for another great transaction!
Old 09-29-2012 | 09:56 PM
davidw221's Avatar
davidw221
I guess you snooze you loose by bad
zachr4x4
11-04-2015 01:38 PM
Brian W
Eastern Performance
01-14-2015 09:35 PM
BuckeyeMan
04-05-2014 08:47 PM
Garemlin
10-25-2010 10:30 AM
klf33
07-31-2010 01:57 PM
