40 spoke frt and rr 16X3 with tires
Off my 2008 streetglide. tires are worn. front still has some miles the rear is close to needing new. rotors come with the front. ABS bearings are in.
If you don't have abs I am pretty sure you can still use these bearings, or you can change them.
they are 16X3 40 spoke.
$350. shipped
$300 you pick them up
They are located in South Carolina. zip 29720
$350. shipped
Do you still have the wheels? Do you know if they will fit a 03 road king? I will try and do some research on them.
You can e mail me direct if you like. kevina3@aol.com
Thanks, Kevin
Thanks, Kevin
I still have them, I don't know if they fit the 03 or not. Let me know.
Had someone ask yesterday if they fit an 02 RK. I think the wheel sizes are the same. the only difference I can think of will be axle size (25mm for 2008) yours are probably 1", which may be remedied with bearing change. Also the rear of the 2008 came with the new IDS drive system. You are getting the wheel only for the rear so I think once you add your pulley and disc you should be fine maybe need a spacer if anything.
Ace07FXDL
Wheels/Tires
01-10-2013 08:31 AM
