a 21inch softail wheel will fit a touring model if you want to run one rotor---I had it on my RoadKing---You guys have nothing better to do? The HUB is the same as if it was a touring wheel.
you would have saved everyones time if you would have just said that in the original post.
Just curious and hope I'm not wastin' anybody's time.
Does a softail 21" wheel with a single rotor have a larger diameter rotor than a touring bike with 2 rotors ?? And if it is a larger diameter rotor wouldn't you have to change the OEM FLH caliper to accomodate, not to mention the reservoir?
I removed one rotor & caliper on my FLH to see if it would work. It sucks.
Again just curious.
