Kuryakyn Dragon Wing Air Deflector 1108
Fitments:
1996-2010 FLHT, FLHTC, FLHTCUI AND FLHX
Condition: Used
Kuryakyn Part # 1108
Dark Smoke
Description:
An easy replacement for the stock wind deflectors found on Ultra Classics or the perfect upgrade for the rest of the FLHT family. Large surface area helps to direct airflow better than other designs. Close the wing vane to guide airflow around the fairing for reduced turbulence during cool weather or open them for a refreshing breeze on those scorching hot days. Adjust to any of four different positions by hand via a spring-loaded mechanism. Shatter resistant polycarbonate construction.
On the left wing only, around the screw holes, there is some internal spider marks in the polycarbonate. These are not cracks. If you run your fingers across them, you cannot feel them. Can't be seen once installed as they are against the fairing.
$ 45 shipped
Visit: http://www.kuryakyn.com/index.cfm/go...etail/IMID/839
for more info.
Condition: Used
Dark Smoke
Description:
$ 45 shipped
for more info.
I will take them. Please provide an address so I can send a money order. Summersr@methodisthealth.org is the best way to contact me.
Terminator69
Touring Parts
07-06-2009 02:48 PM
