cam, s&s gear conversion kit,power com
Series “HG” gear drive cams are made
for ALL ‘07 and ‘08 Twin cam engines
and ‘06 DynaGlides. They have been
designed to run with new 2007 S&S
gear drives. The cams listed below are
the same designs as that have been
made for 1999-2006 engines. Gear
drives made for ‘99-2005 engines will
not fit 2007 Twin cam engines or 2006
Dyna engines.
“HG” series cam installation kits also
include two plates for closing lubricating
oil feed holes which are intended
for stock chain drives, not 2007 style
gear drives.
Performance with the “HG”cams listed
will be similar to 1999-2005 engines
running with the same cam grinds.
Hot street cams for 88 or 95 inches. 80+ rear wheel HP
possible with well tuned 88 motor; more with 95. Smooth
idle, broad torque (2200-5600 RPM) Stock to 9.5 CR.
http://www.andrewsproducts.com/PDF_f...earCam0708.pdf
Dyna engines.
gear drives.
