Dakota Digital Speedo/Tach for 2004-Present
I am selling a Dakota Digital Speedometer unit model #Harley-2004 that is currently on my bike. It has around 3200 miles in it and works great. I really like the gear position indicator and multiple trip settings. I have decided to go a different way with my bike is the only reason I'm selling it. This unit fits 2004 and up bikes with 4 1/2 inch speedos. It has a tach, gear position indicator, clock, 0-60 elapsed time, and and many other features.
This is from the website:
The feature filled HLY-2000 Series electronic instrumentation system offers a 255 MPH speedometer, quick response bar graph tachometer, odometer with dual resettable trip meters and a full complement of indicators to provide a complete information system. Designed to fit all single gauge tank mount applications 2004-2006 motorcycles as well as 2007 and up bikes without factory security systems*, this feature filled gauge will plug directly in to the stock harness!
** Limited Two Year Warranty!
Dakota will set the speedo to your mileage for $20 if you like. This is a great unit that I get alot of compliments on. It sells new for $489.95 and I am asking $325 shipped! PM me for pictures of additional information. I have sold several items to others members with great results.
- 255 MPH speedometer is already calibrated!
Odometer with two resettable trip odometers.
Resettable Miles to Service with warning (user settable countdown) and Hour meter.
Clock (12 hour format)
Quick response bar graph tachometer with adjustable shift point warning.
Gear Position Indicator compatible with 3- 6 speed transmissions.
Various indicators can also be displayed such as Turn Signal, High Beam, Neutral, Low Oil Pressure, Low Voltage and Security Indicators. <LI itxtvisited="1">Voltage readout.
Cruise on and Cruise engaged indication
Automatic turn signal canceling compatible.
"Wait to start" / "Check Engine" light.
Several performance calculations include: 0- 60 time, high speed & high RPM recall, 1/4 mile time and speed.
Chrome front bezel with non-glare scratch resistant lens. - Machined aluminum housing.
* Will work on 2007 bikes with factory security, but security light will not flash even though factory security will still work.
**For 2003 and previous applications use HLY-2002.
Case diameter measures 4-1/4", bezel diameter of 4-5/8"
Dakota Digital Instrument systems are normally shipped from the factory with "0" miles on the odometer. If you would like mileage added to the odometer, this can be done at the factory for a charge of $20. Please contact Dakota Digital to arrange this service.
harleyheaven
Softail Parts
19
01-04-2010 11:53 AM
