FS: Power Commander III 807-510/511 ('02-'06 Touring EFI)
~~~SOLD~~~
This unit is a 805-510 for all '02-'06 touring models, not 807-510.
Had this on my RKC for a little over a year. Like new condition. Recent Harley firmware installed. 100's of maps on Power Commander's website to download and install. Very easy plug and play. Very user friendly. Includes usb cable and 9v battery adapter. If you tell me what map or set up you have, I can load the PCIII for you before I ship. Retails for $359.95. $185 shipped to your door.
- Dynojet recommends use of Power Commander on all fuel-injected motorcycles
- Allows fine-tuning of your fuel-injected Harley-Davidson when changing air cleaner pipes and cams
- Each Power Commander unit comes with a built-in microprocessor and is supplied with a specific map designed to improve performance over stock
- A software package and computer link cable which allows you to fully map the fuel and ignition curve is also included (requires Windows® 95/98/2000/XP/Vista)
- A power programming module is required to supply voltage to your Power Commander when removed from the bike and attached to your PC (must be purchased separately, not required if module is installed on bike)
- Dynojet is continuously mapping different combinations for each bike; special maps can be downloaded at Dynojet's web site (www.powercommander.com)
- If you do not have a computer, you can change the settings with three touch buttons on the faceplate
- No wiring modifications are required; OEM-style connectors are supplied
- Made in the U.S.A.
1stForceRecon
Softail Parts
01-13-2012 05:54 PM
