SE 203 and SE 211 Cams
I have a set of SE 203 chain cams with 7000 miles, great shape and a set of SE 211 chain cams with 3000 miles still mounted on the cam plate including oil pump and a brand new baisely spring (15%) not installed yet, tensioner are in good shape. oil pump and cam plate has 10,000 miles. makes for easy install and no press work.
SE 203 chain cams 85.00 dollars
SE 211 chain cams ready to install 200.00 without baisely spring 185.00 without cam plate and oil pump 85.00
shipping from 95691
went to gear drive set-up
E mail : JohnCA58@pacbell.net
shipping from 95691
these are off a 06 Street Glide, helping the guy out, he brought it over with a gear drive setup and Andrews 21 , his run out is .006 and can't use them. so now we need the Herko set up.
also have a brand new gear set up and Andrews 21 with lifters for 575.00 plus shipping. going to list them also.
I wasn't thinking last night , the SE211 are being offered already mounted on the cam plate with a oil pump, easy install with no press work, 200.00 with new baisely oil press. spring, it is not installed yet, can do it for you or easy to install yourself. I will still offer the cam by itself for 85.00
JohnCA58
08-24-2009 03:14 PM
