Zippers MaxFlow A/C 2008+ Touring
Brand new still sealed Zippers MaxFlow Air Cleaner for 2008+ Touring models. You must have the SE Stage 1 (29260-08) kit in order to use this air cleaner. $53 shipped to your door. I do accept paypal.
http://www.zippersperformance.com/ca...=588&prod=2202
Zipper's MaxFlow A/C Upgrade for 2008+ TBW Touring Bikes
Simple Air Flow Increase for 2008 Throttle By Wire Bikes! If you've installed the factory Stage I performance air cleaner kit 29260-08 on your 2008-up Touring bike, raise the performance higher with this easy to install MaxFlow filter upgrade. This kit includes a high quality 3" deep, washable/reuseable filter element and required longer mounting hardware. This filter has over 60% more surface area than the element it is designed to replace! Accepts the standard TC "football" air cleaner cover (not included). Takes about 5 minutes to install - the difference is immediately noticeable!
Add one of our optional billet open end covers for radical looks and performance!
This kit is designed to be used on Twin Cam® engines equipped with HD # 29260-08 Screamin' Eagle® Stage I air cleaner and the standard Twin Cam® “football” cover, which makes 360º contact between the cover back and the rubber gasket on the filter. Do not install decorative inserts (due to increased weight) or CVO covers that do not make 360º contact between the cover back and the rubber gasket.
Mario77746
Touring Parts
11
05-24-2013 07:26 AM
johnkn
12-17-2008 09:16 AM
